Yes you need new springs and hardened pushrods. The HU1 from sd parts is a great option 212/216 low lift I believe or anything under 220 duration should be fine. A 212/218 is great or the isky triple 12. Good mild cams. A proper tune cam and exhaust will get you around 325 to the flywheel.
