thanks for the info and no my truck does not lay complete frame it is not body drop ok ill check on the ls1 or the cts-v for oil pan thanks...
and also thanks for the power steering info
fabianss357 post a pic of your truck would like to see your set up? if you dnt mind
Lol mine is in about a million and one peices right now.
It was originally bagged to lay frame on 24s before I bought it
And now I'm doing the swap and bodydrop.
I have a thread I need to update around here somewhere.
And if your not laying frame, the truck pan might work ok,
if not you may be able to run the more economical muscle car oil pan kit.
Just FYI, all ls based engines share the same oil pan pattern.
The windage tray and oil pick up tube must be changed out to correspond with the pan your putting in.
Here's a great link for pans, including measurements.
http://m.ls1tech.com/forums/showthread.php?t=1611850
fabianss thanks for the info ill keep posting as the project continues im hope to have everything gathered in like 2 to 3 weeks and then ill start the swap is there anything you think i might need to keep in mind or heads up on something?
