Is the spacer the only diff? There sellin flex plates on eBay for 4.8 up to 6.0 as the same part
We have a 5.3 and 6.0 on the stand at the shop I looked at both cranks they or not different the flywheel I used on mine was flat and used the spacer the flywheel I used is the same on the 6.0 the spacer is like 3/8 thick that's a note to pull converter out of front pump
Ok thanks that's wat I need to know
