I also hooked a signal wire to my fan relay to the green wire. The problem i noticed was when i wasn't running the AC and the fans kicked on it would engage the AC compressor. It was caused from the voltage coming from my fan thermostat signal to the relay would cause it to happen. Then my compressor went out so I've never messed with it any more.
Turns out my AC system was full of air, how in the heck it cooled like it did before the swap I have no idea, friend recharged it for free, gonna run it and see how it goes,,, when I tapped onto the green wire on the compressor I soldered my wire and wrapped with tape, then covered it with loom and taped it again,,,
