so i think i figured it out guys. when i put the double roller timing chain set on it moved the oil pump out a bout a 1/8 to 1/4 inch. and the oil pickup got moved just enough so that it set a little sideways and was breaking the seal. so i pulled it all off and am putting the stock one back in to see if it fixes the problem. but i want to run the double roller setup so what do i have to do?? pull the whole engine to get to the pickup to bed it enough to lineup??
you need to slot the mounting points on the pickup tube so that it moves forward to meet the new mounting hole location.
