Pretty sure thats an EVAP line.....
I'm lovin this :)
disregard lol....
That is a single inlet fuel rail.
The hard plastic line running to the top front with the green cap is the EVAP line.
The hard plastic with the foam sleeve running to the center top is the PCV line, should be ran to that open port on the valve cover.
Your 2 fuel lines on the truck need plumbed to a corvette regulator and then the one line from it goes to the fuel rail inlet.
He was making fun of LamboDoNoMo, not you.
You can just cap that line if you don't want to run EVAP.
Yeah I just cap it and get the vette filter. Knew you had a single line dangit! :) haha last dual lines were in 2003
