i remember when i did my 98 swap the Tach, Speedo, and Gas gauge did not work, a guy named Lance (nitrous) on this forum walked me through it. i had to splice wires from my factory harness into certain pins on the New PCM and harness, i cannot begin to tell you which ones they were, i never got the gas gauge worked out because supposedly they had different OHM readings in the 98 and newer sending units which was causing my issue. i know the wiring in the 89-93 trucks are totally different and so are the gauges so it may be totally different. below are some PMS from a WHILE back im not sure if they will help or not.
u get it working yet
http://www.ls1truck.com/forums/image...quote_icon.png Originally Posted by Wtfan18
i grounded pin 9 and it dropped my fuel gage to emply. so i ran a jumper wire and connected pin 13 and 9 and grounded out 19 but it stayed pinned past full still, any ideas?
http://www.ls1truck.com/forums/image...quote_icon.png Originally Posted by beater6.0
sorry i dont explain my self very good lol pins 13 and 19 are on the same plug .and the purple 9 is on another plug. what u can do is take key on and ground pin 9 to verify it is the right plug gas gauge will read empty. then take pins 9 and 13 hook those toghter. then ground 19 and it should work
although i did find a #9 purple wire on a different plug. should they all be on the same plug or were they supposed to be on 2 differnt ones?
no lol pin 9 is out to the gauge and is purple. pin 13 is purple with a white line on it and there wont be voltage just resistance. and pin 19 is a ground for the sending unit.
from your old pcm wiring harness there was to purple wires pins 13 and 9 they need to be spliced toghter and it should work but u need to make sure pin 9 has some where between 0 and 90 ohms 90 should be full and 0 being empty
hey bud i just realized something the donor truck my sending unit and fuel pump came off was a 97 gmc sierra 5.7 vortec so is there anyway you can explain to me how to bypass the pcm so i can get my gas gauge working! id really apprecaite it. thanks.
