yay if you told him to turn it on he will. if you didnt request it then he might not have
Yeah I told him I have the LS1 e-fans and bought his harness that he makes...so I don't see any reason why he wouldn't.Quote:
Touch the pcm blue wire to the chassis/ground. Do both fans come on low? If so, the harness is fine, if not, we need to get you another harness (easier than troubleshooting).
If they come on put the pin in blue 42, the fans should come on around 189deg for a 160stat and 205 for the stock stat.
I'll get you fixed up right away if anything is wrong.
thanks,
Thanks Allen. I grounded the blue wire and the fans came on so it's not the harness. I put the pin back into 42 on the blue side and let it heat up....still not coming on. Well maybe I will have some luck when that new PCM comes this week. Thanks for all the help everyone.Quote:
thanks,
-Pete-
good luck man
