Elaborate fool.
Elaborate fool.
ductape, is that design you posted for a 1999-06 extended cab or the earlier trucks? also, will it fit without altering the seat?
I think i can build this but i am not sure about the measurements because the wood is 3/4" thick and not sure how to compensate for that when cutting the peices. I keep going over it in my head but keep confusing myself
Will this fit without modifying the back seat? How much lift on the seat is needed?
Also I plan to cut that design by 1/3 and run one ten.
This one......
http://http://www.audioque.com/Stree...ofer_p_10.html
This box fits all ext cab trucks up to the (99-07 classic)NNBS AFAIK. Yes, it fits without lifting back seat. I just built a single 10" ported for my RE SE10 and it slams. You want to go sealed or ported?
EDIT : link FAIL
Box I built for my old truck was dang near exact same dimensions as the first plan you have. Only difference that I can see is that I cut off the bottom 2" in the front. It ended up letting the sound travel better.
That don't look like mine?!?!?
I've heard you stand up an ex cab box and put it behind the seat of an rcsb? Any truth to this and will duct_tapes box work with seats all the way back in an rcsb?
It just depends on what you're willing to do for an audio system. Some setups play louder port forward sub up, and some louder sub up port up, ect. I have a few different box designs floating around here. The one in this thread is for an extended cab under the seat. Somewhere I have one posted for a regular cab, probably in one of Frenchy's threads. PM me details on what you want and I can work something up. Doesn't look like you're too far away either.
