A least it was a cheap fix. Lot of labor, but cheap.
well after doing some research i found this..Quote:
If you need to put a piece of high pressure hose in your fuel tank, be sure it's rated for in-tank use. Your typical parts store high pressure EFI hose is only rated for outside the tank use [SAE J30R9]. That hose will turn to mush in no time.
i had to order it from oriellys part number 27093 gates submersible fuel line
I got my hose from Napa, part number H209.
FYI, 3/8" is NAPA #H213 or Gates #27097.
Good thing you got it all figured out.
yep, i hope that fixes my problem
Is it possible to use braided stainless hose and an fittings? Seems like it would be the way to go if it was possible
