http://i33.photobucket.com/albums/d8...11-09012-1.jpg
allen maybe you could tell me what the relay is for over the brake booster i dont really understand why its there. should i go ahead an cut it out? i still have the stock FP relay on the passenger side by the power block. its wired into the oil pressure sensor, should i keep that too or get rid of it considering your harness is powering my FP
How did you delete the junction block on the passenger side of the firewall? From the diagram I looked at most of the stuff was still needed for the truck.
FarmTruc, what did you use for the water temp reading for the gauge? And also the Steam Port vent?
