Originally Posted by
txarkitekt
I am really confused. :ugh2: All of this doesn't sound right.
First of all, the rockers should use the stock length pushrod...and those are 1.75 ratio--only .05 higher ratio than stockers--a waste of $$$ in my opinion. And a different ratio rocker shouldn't require a longer pushrod...unless blatantly specified by the manufacturer.
Second, you should have had the pushrods spec'd AFTER the cam...not before. But since the cam is ground on a slightly smaller base circle, then a slightly longer pushrod is needed.
I would run the setup, but make sure to get something in writing that shows what pushords are needed for the cam...and what pushrods are needed for the rockers--so that is something bad happens, you have documentation showing it was all spec'd out correctly.
