Good deal thanks G
Good deal thanks G
he figured out the easy way to do the swap and leave it a 5 speed.
well get his ass on here :lol:
Crap! Sorry G. I think I was supposed to do something and forgot. Does it run and drive yet?
To use the stock 5 speed you will need a truck flywheel. the ls1 flywheel won't work with the 5 speed they are different thickness. the throwout bearing wont engage the clutch with the ls1 flywheel. if the wiring harness is auto you will need the prnd switch from the transmission. you will need to plug it into the harness with it in the park position lets the pcm think its in park so you can start the truck with the key. for the dbw you will also need the tac module and wire form the pedal to the module also. before you mate the engine to the tranny be sure to install the pilot bearing into the crank.
your stock fuel system will work just fine.
