Got around to cutting the valve seats and surfacing the heads today. Machine work is now done. 4 angles on the seats, (technically 5, but the chamber cutter only left its radius, not the flat, so I’m not counting it), performed just a tad more hand blending after using the chamber cutter. Intake seats are .040” wide, exhaust seats are .060” wide. Both intake and exhaust valve also have a 30 degree back cut.
During surfacing, I only took .004” off each head, they both cleaned up 100% in .003”. (A huge thank you to my wife for not overheating the engine over the past 160,xxx miles).http://mescal.pixelized.ch/smilies/smooch.gif
Next step is to CC the chambers, setup the valve train, final clean, assembly, then attach the heads to the short block. http://mescal.pixelized.ch/smilies/victory.gif
Intake and exhaust seats just after the first cut, 3 angles, (30, 45 and 60 degrees). The final 2 angles are added with separate cutters.
http://i17.photobucket.com/albums/b8...20up/3angl.jpg
Ready to be removed from the mill after being surfaced;
http://i17.photobucket.com/albums/b8...20up/mach2.jpg
http://i17.photobucket.com/albums/b8...20up/mach3.jpg
Machine work done, awaiting final clean;
http://i17.photobucket.com/albums/b8...20up/mach4.jpg
