yea i got it from mark shaner he said it only had around 1500 miles or so on it. well looks like i'll be tearin the motor back apart..thanks guys
ohm out the wires to the pcm from the sensor, try your other pcm to make sure it's not the pcm.
is this why your truck isn't running as strong as you want or running bad, that would explain it if so
Probably should have got this issue fixed before you complained about the tune in another topic.
it was an '06 z06 cam. the o1 and the 06 are basically the same in specs other than one (01 cam) has the ring on the back of the cam and the other (06 cam) doesn't
Yeah the 06 is a completely different engine. BTW, the 01 cam is a one year only as it changed in 02.
hmm didn't know that. i was just goin off of what someone had told me. well either way i tore it back apart and put a different cam back in it lol
or you could get a LS2 front cover and extend your wires to the front to the front sensor location, and if you do this you must switch wires A and C on the plug.. just a thought if you really wanted this cam..
