Pull the dist cap and check for corrosion on the inside, check the rotor and checl the coil terminal for corrosion. If all is fine RECHECK FIRING ORDER AND MAKE SURE IT'S 18436572. If it's good and only after you've checked it.....TWICE, get rid of those plugs and put in almost anything but bosch
