yea there right by the computer but i will try that thanks man
that and some traction bars and beta tiers will solve your prob
KYB is the only way to go on shocks.
random your right tho beta shocks will help your wheel hop to if you have bad shocks but i don think thats his prob
garenteed its your pinion angle!!! traction bars wont help you much if your pinion angle isnt corrected!!! i have a bad issue with wheel hop cause i have an 8 inch drop...my pinion angle is wayyyy off!! you wanna be at -3 pinion angle for best performance!!
i was sayin if when your pinon is fixed to try the traction bars if you still have the problem
ok ill try that when i get time i got another question for u guys kinda off topic but i changed my plugs ran great for 1 day then started surging at idle i put my stock plugs back in then it went away for about 2 hours and my check engine light came on and ran the code it was misfiring on cylinder 5 i think it may be my plug wires but im not exactly sure
you may have messed one up with the new plugs but other than that it could be your coil
tomorrow im buyins some new msd plug wires and i hope thats wat it is if not my dad is gonna next day air a new coil
