Back to my question though,
1. Will a hydraboost master cylinder be a direct replacement on my truck?
2. Will a older style pump be a direct replacement for the bracket on my motor?
3. Could I just run the breaks that I have and the pump I have and just cap off the vacuum part?
i Have asked the same question and the response on this and other forums was that you could plug one line and use the pressure line for the power steering in and then the return for the out. The top one is the return and the threaded one is pressure out. The other one is what i was curious about and never got a solid answer. I just wanted to plug it or something but i haven't quite gotten that far on my build so i will hopefully find out by then.
