i have 1991 gm wiring diagram book. But it doesn't have connector end view. If you can tell me what cavity from what plug i can search the book till it shows up.
RWAL Diagram
http://i733.photobucket.com/albums/w...6/100_0285.jpg
RWAL Diagram
I think that will help a lot. Is there a diagram that shows all of the wires in the C100 plug?
NO!! I wish there was. That's the connector end view that it DOESN'T have. The book i have for 2001 has it, and i think i saw one on thirdgen that has c100 for a camaro, but its not the same as the truck. I can probably look through it and get all the wires and just post em up off the c100, like if you were under the hood looking at he firewall. I have to go to sams and make a volcano but after that i will see if i can get something together for ya.
Thanks I appreciate the help.
The purple wire coming from the drivers side connector should go to the starter.
It's the crank signal.
The book that r6z406 has actually shows all of the wires in the c100 plug.
You just have to look through the entire book to find all of them.
Well i gotta go to Houston for some family stuff. I won't be able to look through the book till this weekend.
