Sorry, bro. I was only kidding since I have nothing to mount it to.....maybe you don't either. Is there a flange that can be changed?
So here's the deal....the stock T-60 is not a direct swap with the new MP T-70. The differences are on the compressor side. The 70 has a 2.5" outlet and the 60 only a 2" (See below)
http://i175.photobucket.com/albums/w...2/DSCF0206.jpg
This means that I have to get a new charge pipe since the old one starts as a 2" and goes to a 2.5". Is this something I could get at a muffler shop?
http://i175.photobucket.com/albums/w...2/DSCF0205.jpg
The other question is where to reference boost. The old 60 has a port on the compressor side but the new 70 does not. Can I just tap into the charge pipe right after the turbo?
http://i175.photobucket.com/albums/w...2/DSCF0207.jpg
Then I also have to get a 4" filter since the 60 had a 3". Any suggestions??
need you a 2.5" silicone and clamps, some 2.5" aluminum or steel pipe, bends if needed, and a coupler from the 2.5" to mate to your IC which looks to be 3". I put the vacuum line on the engine since boost pressure will be different after cooling.
you could get the pipe from the moffler shop but then you have to get the silicon couplers...i would just get online and buy the pipe and couplers you need and have them shipped they would also have a new filter for you
The reference is for my electronic boost controller and the charge pipe is 2.5" all the way up until it gets to the MAF snesor (inactive but still in place). I have my boost gauge, BOV, meth & MAP sensor all referenced off of the engine. Who would have the coupler and pipe?
Silicone Turbo Intercooler Connectors Hoses, Silicone Hose, Silicone Hoses
if you were closer i have the stuff you need minus the filter...oooo try Pep Boys if you have one near, when i had my nitrous backfire they had all kinds of silicon hoses and crap for the ricers
They're sold all over Ebay too.
Thanks guys!
