A lifted 2wd with a turbo'd 4.3L V6??? Are ya'll kidding? He just installed the STS turbo kit for nothing then cause big tires and all the extra weight of the lift is going to rob alot of power.
bag it. you can go either way a he flip of a switch. it can be low except when you need the clearance or anything that might be a disadvantage of a lowered truck
Ok to start off, your body style truck really doesn't like a triagulated four link. The frame rails aren't wide enough to give the upper bars enough angle to center the rearend properly without some axle movement. If your looking at doing it yourself KP Components has a real nice kit, as well as Air Ride Technologies. Both of those kits are parrallel. There are thousands of ways to put in a 4link but only a few correct ways. If you fab something yourself your better off with a tapered sleave bag mounted behind or infront of the axle i.e. firestone F9000 or f9001. That will give you a excellent ride. If you mount the bags on the lower bars on a lever ratio you need to use double convoluted bags. The weight of the truck, size of bag, determines where the bag should be placed. You can also get a excellent ride this way. There is a lot of stuff involed to get a properly working system. It doesn't matter how the bags are on a 4link system, you should never get any wheel hop period. Unless the 4link it installed horribly wrong. I tried not to make it so long, and it's hard to get into great detail.
Well put. Im not doing the install myself. A guy who used to work at Chaotic and now works with his father will be doing it for me. So a triangulated 4link is not my best option then? I looked into the KP and ART stuff but for the $, the route I explained plus the compressors, bags, and everything else just seemed more economical and more suited to a performance application or so I thought. If I was to bring my truck to you what would you recommend and how much cheese would it run? Feel free to pm me if you would like to get more specific. Thanks for your insight.
Ok cool. Is this your shop # 512-xxx-1854?
