I assume (I know that is a rediculous answer)
Allen tuned it, and the the fans are set to come on at 200 and off at 195.
In the fans section the pull down has aux fan selected.
Do I need to change that to 2 fans and only use the high speed side?
Also if I connect 12v to the a/c request I get no change in idle although the values are to speed the idle up with the a/c is signaled.
It is green/white wire #17 red connector.
Thank you for the help.
