extended cab, i do have a stereo and sub box but nothing huge, running 285/50/20, I think I weigh about 5k.
Does Black Bear do live tunes? I'd get down there to him ASAP and see if that wakes the engine up some. As much weight as you're pulling a converter is going to help tremendously. You probably won't need much more than a 3000 rpm stall. If you don't pull heavy trailers often I'd go with a 9.5" converter rther than an 11" since it will help you rev quicker. If this is a daily commuter truck then I'd go probably around 2600 on the stall but still stick with the 9.5" for faster reving.
I'm not sure what exactly a live tune is. He ships me a cable that I hook to my laptop and plug into my OBD port (i think thats what its called) then the program on the laptop records me driving. i sent that file to him, he collects the data and then puts the tune on a PCM. He sends me that PCM and i put it in my truck. As for the stall. Everyone is telling me to get a stall. How much do they run? Hard to install? What size stall? I want to get a super charger later on, will the new stall work with that?
That is pretty much a live tune. :thumb:
As for a converter, I would find out where your engine starts making HP, or call your cam supplier, and order a converter 200 RPM higher. If its supposed to start building HP/TQ at 2400 get a 2600 RPM stall. I always suggest a 9.5" Vigilante converter for racers. 11" converters are for offroaders and guys that tow a lot. A stall is easy to swap out, just be careful and have a friend handy to help. Stalls run from $200 to $1000 depending on brand and options. Be sure to get a 3 or 5 disc stall to handle the torque of a supercharger.
+1 to that. You should be happy with a 2600 stall with your mods--it has great driveability. I would recommend getting that tune in soon. With a stock converter, it will be a dog out of the hole. If you've got any questions when doing the install--ask a few questions on the Live Tech Help on the main forum screen.
for what it's worth, my stock 5.3L made peak torque at 4000RPM just like the factory rating. A longer duration camshaft is likely to move that RPM range up a bit.
