when you take the drain plug out of the oil pan, will the oil get all over the pipe?
oh gotcha, and nope it should not. I will check though.
looks pretty good. Im likeing these remote mounts more and more.
Yes, we are. ;)
Just a quick question, is there anyway i can buy just the passenger side turbo header by itself, with out the whole intro kit? Im considering doing an LS1 swap into my Typhoon, and this will help me keep the turbo, and yes i know i will hve to make a new DP and, will replace the stock drivers side manifold with a regular 4.3L manifold and fab up a crossover pipe to the turbo header.
Id like one in plain steel, and will have it coated once the mock up is done.
Thanks
Sorry we do not sell just the manifold at this time. Unless it is replacing one from a kit, that was in a wrech or something like that.
Ok that one cold pipe will need to be removed for the average oil change. Meaning if you just pull the plug out quick, the stream will hit that pipe. No biggy just 2 clamps and its out of the way.
later
edit. I scrapped the no crush piping layout, it did not look good and was a P.I.A. to deal with. So lowered trucks will need to take care while baha'ing.:LOL: Air inlet to turbo is 3" and cold side to IC is 2.5".
