So we are going to cut right behind the old connectors. Right at the back of the block. Then install the snap lock fittings and run that to the rail. We may need to install an extension piece but it looks good. The old system was fuel injected but at a lower pressure I think it was 28-32psi maybe. Do you think those flex lines will be ok? They look fine but not sure if they will be able to take the extra pressure.
