<div class='quotetop'>QUOTE(blownshovel @ Jun 16 2007, 11:17 AM) [snapback]96964[/snapback]</div>check your dealership. on warretny cat claims they replace the whole y-pipe, scavenge the catsQuote:
EXHAUST:
Use 2003 exhaust manifolds...... where can I get some flanges that bolt up?
02 sensors how many and location? in Y pipe or near cat(s)[/b]
and toss the rest.. theres your flanges and HO2S bungs.
2 HO2S needs generally at the collection of the four tubes per bank.
<div class='quotetop'>QUOTE(blownshovel @ Jun 16 2007, 11:17 AM) [snapback]96964[/snapback]</div>itd be cheaper to install the fuel pump in the tank and return the fuel from the return line of theQuote:
FUEL SYSTEM:
Inline 255 Walbro
2000 Corvette regulated fuel filter[/b]
regulator on the manifold.
<div class='quotetop'>QUOTE(blownshovel @ Jun 16 2007, 11:17 AM) [snapback]96964[/snapback]</div>use the matching year pedal, i didnt and went throug hthree before finding that my 03 TAC module andQuote:
TBW:
The Engine is equiped with it and I believe I have the control Module but need an 03 newer pedal setup.[/b]
03 pedal work best than the 04/05 pedals...
<div class='quotetop'>QUOTE(blownshovel @ Jun 16 2007, 11:17 AM) [snapback]96964[/snapback]</div>cross breading the two isnt for the timid, nor the easiest fix... fork over the $$$ for the proper swapQuote:
WIRING:
Sort through harness Looking for 2003 HD2500 and 1995 C1500 diagrams....any idea? Alldata?[/b]
harness... youll spend money right and have the project closer to done...
<div class='quotetop'>QUOTE(blownshovel @ Jun 16 2007, 11:17 AM) [snapback]96964[/snapback]</div>tach output from PCM to tach module (baker or dakota digital) to factory tach (note: oe factory tachs are notQuote:
Gauges:
Tach ?
Temp...in head hole
Oil Pressure? Where is a good location to tap in?
Odometer/speedometer? [/b]
fast acting, accurate, nor reliable
temperature will be harder as your OE sending unit (in driver cyl head) is a monster size and really no
way to adapt it to the LS need... like a 15mm x 1.5 LS has like a 8mm x 1.75
oil pressure can be tapped from the oil pan
if youll keep your transmission harness and DRAC.. you speedo will be fine.
airdeano
