the track sucks since there is no way around the water box. No matter what you get water on all four tires. What happens on us street trucks is the front tires get wet and when you warm up the back tires you end up getting the water off them but the fronts are still wet. When you take off, the water from the front tires goes onto the track and the back tires run over it causing them to spin. I imagine it's even worse for an AWD vehicle since you really can't get up there and heat the tires up on all four corners.
