	Quote:
				Originally Posted by  Chevydillan
That's a nice CAI
 Ya I like that it is all black. It is their black hawk edition. The only difference I have found is it isn't CARB approved.
		Well I spent the day working on getting the trans out to put the adapter on the flexplate and I may have inadvertently busted the front pump while bolting the motor and trans back together. I wasn't able to move the converter to line up to the flexplate. It would just rock back and forth about 3/4".
 So it looks like I will be blowing apart the 65E and converting it to 2wd via the output shaft of my current 60E and replacing the clutches and steels as well as doing the vette servo and a shift kit.
		Looks like the 65E is gonna be rebuilt and upgraded internally with any kind of updates as well as a shift kit. Once that is done then it will be a mission to try and have it running by next weekend.
 I almost want to take vacation time to stay on this project to get it done faster. I am trying to do all this in between work and on my days off. But because I am doing it at work, I keep getting interrupted with non sense all day on my day off.
		98% of motor wiring done and alternator relocation/AC retention kit from LEXTECH installed. Just waiting on my dad to rebuild the transmission and add the shift kit and corvette servo within the next couple days and I might be able to fire this bad boy up by this weekend. Then comes bending the exhaust.
 http://i88.photobucket.com/albums/k1...ps8a339652.jpg
 http://i88.photobucket.com/albums/k1...psbfd0882d.jpg
 http://i88.photobucket.com/albums/k1...ps7a69f5f8.jpg
 http://i88.photobucket.com/albums/k1...psd6ef62b8.jpg
		Everytime I see that bracket, it makes me think that GM should have done it that way the first time....
		Transmission is back in the truck. I am going in to work early tomorrow to finish putting the rest of the driveline before I have to get it off the lift.
 I will have some time through out the day to work on little things to button it up to get it running and driving before starting on the exhaust. Wednesday is my day off so I will do as much then as I can. I would really like to see this thing back on the road by this weekend.
 Being sick isn't good either so that may slow down my progress.
		Its in and running and driving but I have some bugs I need worked out before I can actually drive it.
 What are those of you running LS motors in OBS trucks doing with the steam vent line? I need to plumb it somewhere.
 https://www.youtube.com/watch?v=r429lFGHI4U
 https://www.youtube.com/watch?v=AAp4fpUN7DE
		I drilled and tapped my water pump. Works like a champ
 http://i204.photobucket.com/albums/b...psq9xxbdzq.jpg
