Is there a part number for the brake booster vacuum hose if your putting in a 5.3 into a OBS, using the truck manifold? Do I just buy a vacuum hose to fit?
I had a 2000 Silverado extended cab I sold a couple months back and loved the 5.3 I had in it. Had it for 4 years and no issues. Hence this swap I am now doing to my 1994 C1500 W/T. This is my engine first swap. I am mechanically inclined and I recently pulled out the broken 4.3 with 4L60e trans that was in. I was told the trans was rebuilt a couple years back so I would like to reuse it without spending any extra cash. I purchased a bare 2002 5.3 DBC with basically the block, heads, intake and wire harness that had been partially cut. The person selling it got it from LKQ for their truck but sold the truck before they can put 5.3 in. I got this and other parts off craigslist, so I call this my craigslist budget build. Throughout the pass few weeks, I have gotten a 5.3 flywheel with the concaved center (kind of curved in the center) where the bolts go, a 2002 PCM, 2004 full factory truck intake box and hoses, ls1 intake manifold (may hold off till later), just got a full engine harness and few other things from the internet like dirty dingo mounts and the rear lowering kit consisting of shackles and hangers. I swapped the frame mounts to V8 mounts already thru the lower control gap and it was not that hard as long as U have someone else assisting. I also pulled the bed off yesterday to change the fuel pump to a 1996 and later and since I am there, install the lowering kit. This is going to be a simple driver on the weekends, nothing to be raced. I have a few questions that I see different answers, so here they are:
Can I use my 1994 4L60e with this motor? Will a shift kit or a stall converter help with extra power of the 5.3? Which stall converter would be best?
I read up on some people saying to swap out the inside trans harness to that of one of 1996 and later. Or when I have the PCM reflashed, can I tell the one doing, it to disable the PWM for the older 4L60e trans.
I am looking for an inexpensive way to mount the old 4.3 a/c compressor. Is it possible to use the old 4.3 a/c bracket on the 5.3 with some modification?
Can the power steering pump off the 1994 4.3 bolt on the 5.3 alternator / p/s bracket?
I am thinking of deleting EGR and rear O2 sensors. I live in Miami which doesn't require emmisions testing, but I do not want to be killing myself with all those unfiltered exhaust fumes. Can I simply put on a couple aftermarket cats to filter that out? Will they last even thought the O2's will be deleted?
Can I used the 5.3 flywheel that is concaved ( kind of curved in the center) as is or will I need a spacer for the 5.3 to mate with the 4L60e? Or can I simply use the flywheel off the 1994 with a spacer and longer bolts?
Since I pulled the bed off yesterday I saw that the top of the sending unit has a bit of rust and corrosion. I was thinking of changing the complete sending unit. Can I change the complete unit to one off an '02 5.3 ?
I know I am forgetting something, thanks !! This forum is great and is helping me out with this swap, I just had these questions to verify
Here are some pics .......
ON THE WAY TO ITS NEW HOME:
http://i1323.photobucket.com/albums/...pse6165577.jpg
PARKED AT HOME:
http://i1323.photobucket.com/albums/...ps5bccfc91.jpg
http://i1323.photobucket.com/albums/...psf6d169e3.jpg
http://i1323.photobucket.com/albums/...ps11b20026.jpg
FUTURE WHEELS I HAVE SITTING IN THE GARAGE FOR IT:
http://i1323.photobucket.com/albums/...psfcb08dbf.jpg
PULLED THE MOTOR & TRANS:
http://i1323.photobucket.com/albums/...ps3ba4e501.jpg
http://i1323.photobucket.com/albums/...ps7626631e.jpg
THE NEW V8 MOUNTS:
http://i1323.photobucket.com/albums/...ps0d36f3e0.jpg
THE NEW MOTOR:
http://i1323.photobucket.com/albums/...pse79d052a.jpg
THE BACK OF THE ENGINE:
http://i1323.photobucket.com/albums/...psb4f93c18.jpg
THE WAY IT LOOKS AS OF 4/6/13:
http://i1323.photobucket.com/albums/...ps4227a458.jpg
http://i1323.photobucket.com/albums/...psf3955b84.jpg
Need to get wheel adapters for those Camaro SS wheels to fit that truck. Nice project!
Also, the ls1 intake requires a car water pump or you'll have throttle body clearance problems.
Thanks for the reply. I have had the SS wheels for awhile in the garage even before I got the truck. I will have the adapters made in a few weeks, no rush. As for the LS1 intake, I am going to ditch that idea after reading about and speaking to a few people, supposedly the stock truck intake is better for my application. Plus I do not want to go out hunting for different accessory pulleys and such.
Nice work. i am looking for a donor so i can start my 90.
Recently figured out how to copy lots of links at once. These are all somehow related to OBS --> LSX engine swap. This is what I used. It may not be applicable to you or they may not all have 100% correct info. Hopefully it will help others. I can put them in a separate thread if that would be better. Here they are:
Engine/Efans/Wiring/Mounts/Exhaust Links:
http://ls1tech.com/forums/conversion...-oil-pans.html
http://ls1tech.com/forums/generation...r-adapter.html
http://lt1swap.com/lsx_tach.htm
http://i2.photobucket.com/albums/y28...5FanWiring.jpg
http://imageshack.us/photo/my-images...ngfansbu6.gif/
http://www.ls1truck.com/forums/lsx-t...t-routing.html
http://secure.ultracart.com/catalog/.../ACC-1030.html
http://www.performancetrucks.net/for...shrods-505622/
http://ls1tech.com/forums/13174477-post7.html
http://dirtydingo.com/store/pages.php?CDpath=0&pID=11
http://www.pontiacstreetperformance....p/exhaust.html
http://www.exhaustvideos.com/faq/how...pipe-diameter/
http://www.ls1truck.com/forums/attac...6&d=1213474335
http://m.ls1tech.com/forums/showpost...&postcount=294
http://ls1tech.com/forums/northwest-...hine-shop.html
http://forums.corvetteforum.com/paci...s-rebuild.html
http://forums.corvetteforum.com/c5-t...install-2.html
http://www.pacificp.com/forum/viewto...t=7367&start=0
http://www.ls1truck.com/forums/lsx-t...onnection.html
http://www.ls1truck.com/forums/lsx-t...t-diagram.html
http://www.ls1truck.com/forums/lsx-t...or-wiring.html
http://www.carcraft.com/techarticles.../photo_12.html
http://www.popularhotrodding.com/eng...re/0505em_exh/
http://www.youtube.com/watch?v=wQLhI...utu.be&t=7m30s
http://www.ls1truck.com/forums/lsx-t...g-removal.html
http://www.summitracing.com/parts/edl-3864
http://www.ls1truck.com/forums/lsx-t...e-fitting.html
http://www.ls1truck.com/forums/lsx-t...-canister.html
http://www.performancetrucks.net/for...3/#post4711055
http://wpdev.injectordynamics.com/ar...ure-explained/
http://www.youtube.com/watch?v=1Ew1YSm8jd0&app=desktop
http://m.ls1tech.com/forums/showthread.php?t=102153
A/C Links:
http://www.ls1truck.com/forums/lsx-t...bracket-2.html
http://www.maliburacing.com/forum/vi...p?f=34&t=79059
http://www.novak-adapt.com/catalog/a...cation_kit.htm
http://customimagecorvettes.com/stor...cessories.html
http://www.ls1truck.com/forums/lsx-t...tegration.html
http://www.ls1truck.com/forums/lsx-t...ok-up-how.html
http://67-72chevytrucks.com/vboard/s...d.php?t=510656
NNBS/TBSS Intake Swap Links:
http://www.performancetrucks.net/for...-today-500762/
http://m.performancetrucks.net/forum...d.php?t=493269
http://www.gmfullsize.com/forum/showthread.php?t=264691
Head/Cam Swap Links:
http://www.ls1howto.com/?article=2
Awesome list! Really appreciate you compiling these
I'm going to be leaning on this thread pretty heavily in the near future. Great detailed info
What are the normal header choices for 4WD tahoes?
