I am thinking about doing this servo swap but am a little hesitant because of the potential problems. My truck has 109K on the clock and afraid that this swap will cause some serious damage. What do yall think?
99 silverado, 4WD, Reg cab, SWB, 5.3, 4 wheel disc, magnaflow, K&N, hypertech PP3
put the Corvette servos in. These billets will probably kill a trans with that many miles on it. The Corvette servos can be purchased for under $30 most any place and will work just fine on a stock setup. If you later have a trans built for performance, then have the billets put in or just stick with the Corvette servos.
Cool man. Im going to be doing the throttle body bypass and corvette servos on thurs. Thanks.
the servo is a great upgrade but I wouldn't worry about the bypass. the perofrmance gain isn't enough to be worth the cold start problems.
well I live in Texas so cold starts wont be a problem. plus i figure with all the 5/16 hardline i have at hand, why not? I mean I dont have the money for an aftermarket throttle body. Serving the public just doesnt pay....
With this Corvette servo, should I get the kit with the longer pin/shaft or should the stock pin/shaft work? Reason I ask is because I found a kit with the servo and o-rings for $15. The complete kit I found was about $45.
with the corvette servo there is no reason to replace the pin. :twocents:
Corvette servo, best $30 I ever spent. Thanks for the help guys.
99 silverado, 4WD, Reg cab, SWB, 5.3, 4 wheel disc, magnaflow, K&N CAI, hypertech PP3, corvette servo.
