Ive been thinking about upgrading my 99 pcm for an 02 pcm. But im not quite sure of what all that I need. From what ive gathered i think that i need the 02 pcm, a pcm clip to run a wire from terminal 52 to the alt., and an 02 bcm that the dealer has to flash my vin into from the 02 pcm. If anyone could help me and tell me exactly what i need that would be great. Also i was wondering if an 05 pcm would work on my 99 and if it would be better than the 02 pcm.
I don't think you have to go through all that BS. Contact Allen, he can burn you a PCM to work with your system.
First off, you dont need that wire. It is either an L-terminal for F-terminal code that needs to be turned off, I forget which one, and that takes care of the light.
Second, you are going to have to use an 02 Vin #. You cannot flash a 00 vin number onto that OS. Just contact Allen like Red said and he will take care of you!
Chris
Alright. Thanks guys for your help. Im trying to save up some money right now to get a tune from Allen but with x-mas and all it is kinda hard right now. But by January for sure, I cant wait! :smile:
