i have a 94 chevy 1500 full size extended cab truck with a throttle body injection V8 5.7 liter 350 and i want to put and ls1 in it but i need some help as to where i can get the parts, motor, and info on the swap
you can get most of the parts over Ebay, orielly and autozone. The engine can be bought at any salvage yard. The help can be found here. Check the LS1Conversion page for help, part numbers and anything else. The conversion has been done soooooo many times, up to 4 times personally here along with 2 LT1 conversions.
thanks alot but will i be able to use my stock motor mounts and how hard is it to wire in the ls1 computer
You will need your stock motor mounts and the reciever cups that mount to the engine block. The reciever cups will bolt to the adapter plates you buy off Ebay or from Street and Performance. Most guys use the Ebay versions, cheaper, thinner and quick shipping. The PCM will plug into a LS1 harness only. You'll have to wire in the LS1 harness into the factory harness. A ready made plug and play harness is the way to go if you're not sure of your wiring abilities. There are only like 5 or 7 wires you have to hook up and they are labeled. All you have to do is figure out which existing wires you already have do what. A wiring diagram from Chilton, haynes or books like that are a good start.
ok well thanks alot again for ur help ive been posting this on ls1 tech 2 and havnt gotten anything back can you make me a list of what all i need and about how much its going to cost me, thanks again
Check back posts. We did this a couple weeks ago.
oh ok well ive been lookin but havent found anything that really helps
thanks alot man i just found a smashed up 2002 ss camaro(SLP edition)and hes gonna give me a really good deal on the motor and harness cuase it turns out hes my dads freind, im only 16 and ill be doing most of the engine swap my self ive done many engine swaps before but never an ls1 i also plan to make a custom header for a turbo and the exhaust i will make and weld together my self, thanks again, let me know what u think about the turbo
