I notice the TB habe conducts that take heated water by it.
Saw it and is kind of easy to take it out.
Here we have a hot weather 24/7/365 so will that give a good charge of cool air to the manifold? Mo' Power?
Just consulting?
Just consulting?
That is usually the first performance modification that guys make. They call it a free conversion even though you have to buy a tee or adapter to connect the two hoses together to bypass the throttle body preheat tube. Go for it. I believe step by step instructions on how to do it were post on another website... www.LS1howto.com or something like that.
Every little bit counts but I have not done this mod because it supposedly only gives a 2-3hp advantage...
Mr. P.
Tomorrow morning will be done....
Thanks.......any more of those "FREE" performance mods?
I've heard of cutting back the egr tube on cars but I don't know if it works the same on trucks. It does look like it restricts airflow.
Ehi! Stavo scorrendo Instagram in Italia e mi è uscita una clip di Gates of Olympus con i tumble a catena. Ho impostato 100 spin a stake basso, intervallati da pause acqua-caffè. A metà ho messo nei segnalibri spingranny per replicare la stessa griglia domani. All’inizio niente di che, poi un 100x ha raddrizzato il grafico. Non ho cambiato puntata dopo il colpo, ho solo chiuso la sessione: a me funziona puntare sulla disciplina più che sulla fortuna.
