What parts are interchangeable from the 5.3 to the 6.0?
Cam?
heads?
Intake?
Accessories?
and so on?
This is just me being curious?
Cam?
heads?
Intake?
Accessories?
and so on?
<div class='quotetop'>QUOTE(shwarmy @ Nov 21 2006, 11:46 AM) [snapback]74096[/snapback]</div>Everything except pistonsQuote:
Cam? yes
heads? yes
Intake? yes
Accessories? yes
and so on?
Now here is a different question. Can you stroke the 6.0 and what would it make it? My cam in my truck is a 220/222 .581 114lsa. How good of a cam is it in a 6.0 motor?
4" stroke would be a 402 and if you bore it .030" oversize it would be my engine, a 408" 6.7L monster. :thumb:
<div class='quotetop'>QUOTE(shwarmy @ Nov 22 2006, 07:17 PM) [snapback]74291[/snapback]</div>Stroking the 6.0 is very popular, new displacement is 402 cu-in; if you also bore the block .030-over then the new displacement is 408 cu-in. Your cam would be a lot happier in the 6.0 than the 5.3 IMO, but if you are going to stroke it you would probably be happier with a larger cam, too (although that one will still work and make fair power).Quote:
Mr. P.
<div class='quotetop'>QUOTE(RedHeartbeat @ Nov 22 2006, 09:53 PM) [snapback]74304[/snapback]</div>Red what cam specs do you have on your motor?Quote:
I run the Comp Cams 54-448-11 camshaft, I think. That's the largest commercially available off the shelf Gen3 cam available. Beyond that is custom specs. I have a very conservative tune. I had Allen back the timing way down while I break the engine in. I am sure there is more than 500 HP hidden in there once it's cut loose and tuned properly.
54-448-11 Click to enlarge LS1/LS6 XTREME XE-R HYDRAULIC
COMPETITION CAMS 54-448-11
Description of COMPETITION CAMS 54-448-11
LS1/LS6 XTREME XE-R HYDRAULIC XER287HR
RPM Range 2800-7200
238/240 .605/.609 112 lsa
This hydraulic roller camshaft is designed for large cubic inch ls1 based engines and is considered a race only application. computer tunning is required.
Go big or go home!
