Stock tire size is 265/75R16, so I would be dropping a little in height. Anycomments good or bad?
I know it would affect my speedometer and so forth, but could I just get Allen to adjust my tune?
They will work fine. Allen can adjust your speedo for you. He did mine when I put 4.10s and 20s on my truck.
It will also have the effect of having a lower gear....your 3.73 is going work like a 3.85.
<div class='quotetop'>QUOTE(spinz71 @ Nov 15 2006, 03:50 PM) [snapback]73661[/snapback]</div>Quote:
And the effect of that would be...?
<div class='quotetop'>QUOTE(DamnYankee @ Nov 15 2006, 03:53 PM) [snapback]73662[/snapback]</div>A small amount of increased multiplication of your engines power. A very minor increase in rpm. Kind of the same effect of swapping gears from 3.90 to 4.10s.Quote:
i just put 255/65r16 on they look a little small but the 265/70r16 should look just fine. your speedo should not be that far off if you old size is close to the size u will be runnin
I'm running 265/60's and they do just fine.
