Finally fired it up tonight, but the thing wont stay running.. The only weird code im getting is p0452.. I looked it up and it says something about fuel tank pressure sensor circuit low voltage.. Basically the sensor is seeing no vacuum.. Im not really sure where to start.. Also Allens harness has no plug for evap canister.. Do i need this for the motor to run correctly.. I can get it to run for about 10 seconds and then it dies..
Thanks in advance,
Drew
