ive ordered a LS2 SSR intake to air in an air delivery problem with trying to draw
air from the area right above the radiator. like the ram air t/a does. because
the 1999-2006 use a straight on design this places the air inlet at a "lower"
attitude. the LS2 manifold moves the tb back and gives a less aggressive
downward angle.
using a format like the f-body for air delivery this upgrade should help.
at first ill use the OE 75mm tb with and adapter and then swap to
the newer 90mm.. just gotta figure out the TPS1 on the newer tb.
the LS2 uses an integrated TAC module and doesnt need TPS1 reference
and ground.
airdeano
