I want to put about a 100 hp wet shot on my truck. Is there a test port on the fuel rail to tap into for the fuel ? or how is this connected? :help:
There is a fuel test port on the passenger side of the engine on the fuel crossover tube.
Chris
Yeah, if you buy an EFI nitrous kit you will usually get a fitting to screw onto the shreader valve after you remove the valve core.
