I playing in HPTuners and have my stock bin and a custom tune bin. When I go to copy and paste the Transmission Auto Shift pressure table, the Normal table won't paste all of them. It stops pasting at 440 and won't let the pressures go paste 96. I'm trying to get them up to 131 during the 3-4 shift at 640. Anyone else ever have this problem? This is the only table I can't change for some reason. chris, I'll try to get back with you today sometime. I got your PM.
Yup I have the exact same issues with mine. For whatever reason, certain tables seem to be limited on what you can enter into them. I found this on the line pressure table as well as some other weird engine tables too.
I was going to post this same question over on HPT forum but never got around to it.
EDIT: I just started a new thread over there about this if you care to see or join in with me.
http://hptuners.com/forum/showthread...1952#post41952
I'll do it right now. Thanks
Hey your max line pressure is 96, you cant go any higher than that. That limit is set in the software and that maxes it out. The numbers will go up higher, but under the shift pressure table, there is a box to set what you want the limit to be.
Did you get what I was saying about the copy and paste on your tune? What version software are you running? It is super easy using the compare feature, anytime before noon I am here man. I work from 12-7, but after that I am cool also.
Chris
Sorry for not replying sooner, but I got the tranny working great! I went to jimmyblues school of tuning LOL. It runs better than ever now except for the LT B1 and 2 are in the red and reading 25. I logged it and it shows fine. Pretty strange huh? As far as adding Nitrous goes, I don't need it until I get me some tires that will hook up. I heated up the Nitto drags I have and I still spin the tires. I think it's time for a 4 link.
