Hey guys, I upgraded to a new model interceptor gauge. I have a few q's if any body knows, cuz the instructions dont fully explain the different things the gauge does. for instance it measures horsepower but on the gauge it reads 0.0 at all times, you can adjust the horsepower scale but im not sure how, ( ALLEN, Do you know?) also the 1/4 mile and 0-60 seems to be a cool feature, ill post results ASAP and we can see how close this gauge is. -Later TIM
Sounds like you are missing the PID's ({well thats what hptuners calls them) for that equation. Would the HP need mph, acceleration, truck weight and something else to calculate that? Or am I completely off?
Are there only a certain amount of things you can log at one time? Check and see if the instructions tells you what else you need to be logging to get this equation.
thats the problem, the instructions DO NOT cover the horsepwer, fuel mileage, and 1/4 mile . uses.!! , it gives you their website to down load full instructions but i tried that and only the old instructions for the older gauge come up. this sucks, i want to plasy with it but cant figure it out yet. it is supposed to be monitoring all is need for these calculations, as it is always plugged in to the obd2 connector.
hmmm thats weird, if its plugged into the pcm it should have all it needs. Have you gotten ahold of Allen yet to ask him?
Chris
no, i was kinda hoping he stumble across this thread, im sure its a simple solution, thanks for your ideas chris. :hshake:
:twocents: Hello Tim, I downloaded the right manual V1.4. Go back to the web sight www.aeroforcetech.com and you will find 2 Versions. Maybe their link sends you the wrong one, V1.3. [Haven't had time to play with it yet.]
Got my duct tape handy and ready. :twocents:
thanks bud, i'll check it out! you guys are the BEST :thumb: !!!!
