Quote:
Get the 918s and hardened pushrods. Hold off for the longer pushrods until after testing your stock ones in it for correct length. If you have access to a micrometer or calipers, measure the smallest diameter on the cam lobe on the new cam and your old cam. 1/2 the difference between the two is how much you need to change the length of the pushrod, if any. Stock is 7.400. If the new cam lobe is smaller you will need a longer pushrod.
Thanks Red...When I was talking to Futral they said the stock length rods should work with this cam but said I would probably want to get hardened ones.
