Quote:
			The truck is a 2000 silverado short bed 2wd, it had the 4.8 in it and was replaced with the ls1, I didnt install the engine so i am going through everything makin sure it is right and there are a few plugs and such that are not connected. I installed an ls1 in my 2000 camaro ss and had no trouble but just not familiar with the truck! There is a single one wire plug that is blue right beside the computer that i cannot determine where it goes, and the wire coming from the ground terminal of the battery, once these are found, it should fire.
Did you experience any security issues when doing the install, starter will not work at this time, I am thinking it is a security issue?
Thanks for you help
