Anybody know the stock fuel pump flow rating, liters per hour or equivalent?
If you have one it's easy to measure yourself. Disconnect the fuel line at the filter and hook the line up to a catch can. One of the wires in the OBDII connector will energize the fuel pump. You can measure it for a given amount of time and then calculate the volume or you go for a measured volume and calculate the time. I like tests like this but I don't have a stock unit around here other than an old OBS pump.
The only reference I found for the pumps show 155.2LPH but am not too sure if its the same as yours. They ref EP381.
<div class='quotetop'>QUOTE(RedHeartbeat @ Jan 15 2006, 01:15 PM) [snapback]41046[/snapback]</div>That sounds about right. I was trying to find the horsepower limits of the stock pump and came across these charts.....Quote:
_____Absolute Maximum Horsepower
_____12 volts 14 volts 17.5 volts
88 lph 222hp 267hp 324hp
110 lph 278hp 333hp 405hp
155 lph 391hp 470hp 571hp
190 lph 480hp 576hp 700hp
255 lph 644hp 773hp 939hp
320 lph 808hp 970hp 1178hp
_____ Effective Fuel Pump Size
88 lph 73 lph 88 lph 107 lph
110 lph 92 lph 110 lph 134 lph
155 lph 129 lph 155 lph 188 lph
190 lph 158 lph 190 lph 231 lph
255 lph 213 lph 255 lph 310 lph
320 lph 267 lph 320 lph 389 lph
Don't our trucks run on the 12 Volt system?
yes 12volt I would always recommend after full bolt ons to put an inline fuel pump in for sure makes a big difference in FP and also adds alot to pice of mind
I got tired of trying to figure mine out so i just installed an in-line last week. It's true i do have peace of mind now!!
