I've decided to call it quits for car audio. I'm happy with simple factory audio and upgraded speakers. I'm keeping all the subs and amps for now. I paid a mint for the amps and may split it up in a few different vehicles.
To sell I have:
1. Phoenix Gold Bass Cube. It's white, has minor wear, a few scuff's. Everything pictured is included. I paid $120 new, I'd like to get $75 SHIPPED OR MAKE OFFER
Picture:
http://i2.photobucket.com/albums/y28...Picture001.jpg
Description of what the hell it does: (Yes it is bad ass and works!)
The BassCUBE (Constant Useable Bass Enhancement) is basically a single-band parametric bass-boost/level controller which will allow you to select a frequency between 20 and 110 Hz and apply a gain from 0 to 15 dB on that band. It allows you to select between a narrow Q (for ported/bandpass systems) and a wide-Q (for overall tweaking of a sealed system). These two settings affect how much the frequencies on either side of the center frequency you select are boosted, or the "width" of the boost, with gradual falloff. Also featured is a switch to go between a fixed or tracking 18dB/Oct subsonic filter, which is another option that allows you to tweak this unit between a Ported/Bandpass and Sealed system. The fixed subsonic filter is just that, and is used for sealed systems, where a tracking filter can be applied for a ported/bandpass setup, to save your speakers from damage when going below the tuning frequency of your ports.
The processor itself is an outboard unit, designed for trunk mounting and has Gold plated RCA inputs and outputs, and will accept a maximum 8V input and output a maximum of 8V, so it integrates into high-volt output headunits and line drivers easily and improving/maintaining a good signal to noise ratio. There are two switches on the unit, one for selecting your Q and the other to switch between tracking modes, and also an input for the outboard controller dial. The dial simply has a pot for controlling gain, and you push it in or pull it out to turn the effect off / on respectively. It also has another smaller pot for selecting the boost frequency.
The cable that interfaces between the outboard dial and the trunk-mount unit is simply an 2-line RJ-11 phone cord, which they supply you with an 18' length of it. Having the phone-cord interface makes it really easy to get shorter length cords should you decide to mount the unit closer than the back of the vehicle, without having to spend a hundred dollars on some proprietary cable. I found the length of the cord supplied ideal, considering my experiences with the shortness of the cord on the DEQ-9200 (3ft). It will basically reach anywhere in any normal vehicle on the road today, including suburbans and the likes.
Gain: 0 to 15 dB
Center Frequency: 20-110 Hz, infinitely variable
Bandwidth: Setting of Q=2 or Q=6, narrow or wide
_____________________________________________
2. Pioneer KEH-P7800 Headunit. Casette player flipdown face. I chose this one for the clarity of the sound. Volume buttons show a bit of wear, display is kinda dim--I'm not sure how to turn up the brightness. I also used this headunit to control the CD-changer listed below. Comes with remote, and face plate case. Remote is missing battery cover. I got this new from best buy in 2000 for $300. First $75 takes it *OBO* $10 shipping
Picture:
http://i2.photobucket.com/albums/y28...Picture012.jpg
http://i2.photobucket.com/albums/y28...Picture011.jpg
http://i2.photobucket.com/albums/y28...Picture010.jpg
Features
Supertuner III™
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
Full-Logic HPX Dual-Groove Tape Mechanism
Music Search
Dolby B Noise Reduction
IP(Interactive Pioneer)-Bus System Control
6, 12, & 50+1 Multi-CD Players
Component Single-CD or -MD Players
Voice Commander (CD-VC60 or CD-VC50)
10-Character Display for Disc Title Memory & MD Titles
Disc List
MOSFET45 (45Wx4-Channel High Power)
RCA Preouts (x2 pair) (Front/Rear) (2V)
EEQ Performance Chip
3-Band Parametric Equalizer
Easy EQ (EEQ) switches 5 Factory, 1 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom)
Selectable Loudness Control (Low/Mid/High/Off)
Selectable FIE (Front Image Enhancer) (Rear LPF 100/160/250Hz)
Full-Flap Face
Detachable Face Security™
Remote Control Sensor (for optional CD-SR77 or CD-R600 Remote Controls)
Multicolor EL Display
__________________________________________________ _____________
3. Stinger 12v Electric cooling fan
$10 SHIPPED
http://i2.photobucket.com/albums/y28...Picture007.jpg
4. Pioneer CDX-P650 6 disc CD-Changer. This WILL play CD-R & CD-RW
You must have a pioneer headunit to control this cd changer, OR get the FM modulator? I used the above headunit to control it. $85 SHIPPED *OBO*
http://i2.photobucket.com/albums/y28...Picture008.jpg
http://i2.photobucket.com/albums/y28...Picture009.jpg
Specs:
6-Disc Capacity
8x Oversampling, 1-Bit D/A Converter
AGC (Automatic Gain Control) for Optimum CD Tracking Performance
Playback Compatible with Digital Audio CD-R (when disc is finalized)
Ultra-Compact Size for Increased In-Car Installation Flexibility
Vertical/Horizontal/Angled Mounting Capabilities with Multiple Mounting Angles
"Double-Floating" Anti-Vibration System
High Speed Disc Load and Access
CD-Text Decoder (for use with CD-Text encoded CD’s & Compatible Headunit)
Disc Title Memory (100 Discs)
ITS Memory (for Programming up to 24 Tracks per Disc x 100 Discs)
IP-Bus Compatible for use with All IP-Bus Multi-CD Player Controllers
FM Modulation and Control Available with CD-P75FM (Optional)
Voice Control Available with CD-VC60 Voice Commanders (Optional)
Uses the JD-612S Magazine (One Included)
Dimensions (WxHxD): 9-3/4" x 2-5/8" x 6-5/8"
5. Pioneer CD-635 Electronic Crossover. 3-way electronic crossover
The CD-635 is designed for those who demand the high degree of flexibility offered by a component 3-way system. Two continuously variable crossover points accurately separate the High, Midrange and Low (subwoofer) frequency bands before amplification.
$45 SHIPPED *OBO*
Specs:
Variable crossover frequency (Mid and Low: 50 Hz – 200 Hz or 500 Hz – 2 kHz, High and Mid 3 kHz – 10 kHz)
Cut-off slope: -12 dB/Oct (all ranges)
Subwoofer and High Range Phase Switches
Subwoofer output Mode Switch (Stereo/Mono)
Level Controller
Gold-plated RCA input/output terminals
Drop me PM if you're interested in anything. We can work something out. I have no use for this stuff anymore.****
I'll trade everything out right FTF for trades. I'm looking for a 12 guage pump. I'd like to have a 11-87 Police (I can add $ to this as well if thats the case), or a Remington 870.
