i just had to have my tranny rebuilt again and now that its back in it all of a sudden is poping up a the code p1336 something about the crankshaft sensor and going to have that looked at by a pro, but now when u put the tranny in reverse it kills the motor , can be giveing it gas, no gas , foot on the brake or foot off the brake, could this be caused by whats poping the code or could it be something else,
thanks for any help
drew
The code is a crankshaft relearn, it's more than likely unrelated to the truck stalling.
Can you keep the engine running when you put it in reverse by giving it more gas?
allen
unfortentallyu no i cant, no matter what i try it stalls out, i was looking though past posts and was wandering if it could maybe have somthing to do with the nutral saftly/gear selector switch , could it have gone bad/be going bad, or with the slots that are in it where that bolts attach it to the tranny could it maybe not be lined up right ?
ok i was out messing around with it tongiht to try to see exactally what was going on with it, make sure i had all the descriptions right on here , i can get it into reverse and only once in awhile will it stall out, but will stay running, but then when i touch the gas will it stall out, and when it does stall out , its like it surges then stalls out, what would cause it that it only happends in reverse and not in drive ? i had the pcm tuned by allen could something have not gone in right on it and that the cause of it,
thanks again for any help
drew
