I installed new 93 oct tune in my 03 5.3 Silverado. I got SES light with code PO315. Does anybody know what this code is?
Believe that is the crank relearn.
what is the procedure?Quote:
Read my post in PCM tuning.Depends on where you are and if you can get to a dealer :bash: Or better yet go see Allen :duh:
I just figured out that your in new jersey.Long drive to texas :eek:
P0315 - Crankshaft position (CKP) system variation values are not stored in the PCM memory.
Any shop with a decent scan tool can perfrom the Crankshaft Relearn and clear the codes.
Got late at night and bring at least a $10 spot :hshake: Takes about 5 mins.
Do you need just an OBD II scanner or what?Quote:
I could find lots of guys with software up to 03 but not 04-05 snap-on,matco,and hptuner software can do it or go to the dealer...but its 75 to 95 dollars for them to do it :bash:
Well I can only speak for myself. I have a SnapOn Modis, Scan Tool/ LabScope. Heck I only work at a Tire Kingdom lol. I get $80 for Engine Diags.
My boss leaves about 5pm So the cash window opens shortly after :)
$10 or even a thank you would be fine with me.
I have a OTC Genisys at home its only updated to 2000. (my $3000 paper clip)
I can read codes, view all the datastreams, run special test IE. crankshaft relean, iac...etc on any GM vehicle upto 2005 I Just running the vehicle as a 2000 Silverado...etc and it works.
You can just goto autozone and get the codes cleared. If your truck will run now it will learn it on its own. HTH
