i have the 4.8 in, i re worked a dbw harness to dbc. installed everything and when i turn the key it sounds like the pcm starts but it doesnt crank and the fuel pump doesnt prime. is the body harness different between the v6 and v8? do i not have a ground hooked up properly? this seems like its been way more difficult than it should be. any help is appreciated. thank you
