I know the tech 2 is mainly for diagnostics but i know it can also change some setings.. i wanted to knoe if the tech 2 can remove torque management and if so how to use the tech 2 to remove it
the tech II is a scanner and some what of a bi directional device, however , the changes it makes are not permanent.
you can cycle tests, raise idle, lock the tcc, etc...
no programming from it, you'll need predator or ls1edit
yep farmtruc is right no changes are saved it can upload the latest gm programs to the pcm and also data log every bit of info from the pcm and the other computers. Its a very powerfull tool for diag. I use it every day
Dustin
GM ASEP student
