Has anyone experienced an issue where the computer will not engage the compressor.
High pressure and low pressure and reading correctly and has correct pressures.
I have taken the control unit and plugged it into a different truck and it worked just fine on the other truck.
The relay can be grounded out and it will engage the clutch and the AC works great.
Each wire to the compressor has been checked and appears fine.
Any thoughts?
