1995 K1500 5.3 Swap Questions
Ive pretty much got everthing I need figured and know what to get. Just a few questions I have left.
Seems like a 99-02 throttle cable works with a few mods correct?
Im trying to reuse my 95 4l60e, Ive emailed two companies that make stand alone harnesses and uses a 0411 pcm, one says I cant use the 95 at all, other says I can, just have to disable pwm in the ecm. I have probuilt automatics pwm eliminator kit to install and I have a 97 4l60e valve body. Will either of these make the 95 4l60e usable with a LS swap harness and 0411 pcm?
I already plan on buying the adapter kit for the older trans to ls motor, but just out of curiosity, is there anyway to swap in a LS input shaft into a older 4l60e? What parts will I need if this is even possible?
I re use the original gauge sending units in the LS motor to keep gauges functional right?
Think thats all I have for now, thanks.
